Drw814
- Oct 24, 2017
- 0
- Ford
Recently I have noticed a clunking noise over bumps in the road from what sounds like the front of the truck. A few months ago my caliper bracket was a little loose and it sounds very similar to how that sounded. This time around I have gone under the truck several times and made sure everything is tight (it is). The noise goes away under braking, even slight braking. It sounds like it's originating from the front passenger wheel. Recently the front wheel bearings have started howling, so I ordered those up and will be installing them soon. I lifted the truck up and couldn't feel any slop in the pass. front wheel and it spun smoothly, but I got under the truck and punched it a few times to get this noise (see below). Only when punching the bottom of the tire, not the side.
https://m.youtube.com/watch?v=Epb5sbg6Kpk
Any ideas to what it could be? Ball joints? Shocks are 3 months old, as are calipers, caliper brackets, rotors and pads. All hardware is tight including manual 4x4 hub locknuts and rings, and lug nuts for the wheel. Thank you.
