Clocking the tie rod end
cmequestionu
16
Federal Heights, Colorado
Solid Axle Swap 4x4
~10
I have a "Y" link steering setup. It has the one tie rod end that has a tapered hole built in for another tie rod end. My problem is I need that hole to be vertical and it is horizontal. At the risk of getting chewed out here is my question: (keep in mind I AM a certified welder and will be using a TIG(GTAW)) can the tie rod end be welded? More specifically can it be cut between the hole and the end, beveled, clocked to the preferred orientation and welded back together? Is there a special rod required? I know there are tapered inserts that require being welded in so that's why I'm hoping this is possible.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Sounds like you have the wrong tie rod end. What axle do you have? Any pictures of the steering setup?
cmequestionu
16
Solid Axle Swap 4x4
~10
cmequestionu
16
Solid Axle Swap 4x4
~10
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
In a hypothetical universe a person might claim that if such material were cast iron then use erni99. If this hypothetical part were cast steel then er70s2/6 would be sufficient however, and again completely hypothetical, er309L would probably be more ideal. Also say someone were to do this... It cannot be simply cut and butt welded, it needs to be cut and beveled to 100% or cut and welded then sleeved, and then welded again. Again, hypothetical answer only.
However given the amount of various tie rods out there and the obvious custom nature of this hypothetical endeavour it would make more sense to find a proper tie rod...
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
That is the only way the orientation is on TREs that I've seen. You would need to get a high steer setup for the other direction.
cmequestionu
16
Solid Axle Swap 4x4
~10
So in this completely hypothetical, damn near laughable situation, how would one find out what material it's hypothetically made of?
cmequestionu
16
Solid Axle Swap 4x4
~10
Yeah, high steer isn't in the budget, unfortunately. The knuckles I have don't do high steer, at least not in the off the shelf way.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Magnet or spark test hypothetically. Steel is yellow iron is orange/red spark. Or a magnet will jam to steel quicker than iron but you need 2 known samples to test first to see the difference for either test to be 100% sure.
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Heat it red hot and twist it 90°?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm glad we're not in the real world...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Me too! A person hypothetically with an AWS SCWI would be screwed if he or she gave advice resulting in stupidity.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
If the axle is a Dana 44 you could find a 77 and earlier chevy/gmc and pick up the right side steering knuckle for about 20.00. then you could have it milled for a ORD Dana 44 high steer setup. I don't know how much it would be to mill it now but I had mine done for 44.00 8-10yrs ago.
Actually you would need both sides steering knuckles off a gm truck.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
You are loved.
