Cleaning burned on oil off carb
kevinbmx77
Got a carb with some baked on oil from a leaky 302 my friend has (no clue how it got into the carb) but its inside it and im worried about it catching fire, anybody know something i can soak it in? Right now its soaking in gas, I've tried diesel but it didnt work, maybe a mix of purple power and something
Sent from my SM-G920P using Tapatalk
ericbphoto
Overlander in development
TRS 25th Anniversary
16,761
Wellford, SC
3.0L
6"
Did you try...
"carburetor cleaner"?
Just a thought. Maybe oil vapors from PCV valve in air stream caused the buildup. I'm just guessing.
black_demon69
142
AZ
4.0l
just get a rebuild kit for carb and this https://www.berrymanproducts.com/products/eco-friendly-products/berryman-chem-dip-carburetor-and-parts-cleaner/
to soak carb in.. it will look brand new and work like new once rebuilt and adjusted..
kevinbmx77
Did you try...
I have not, i didn't think it would remove the oil, but i will give it a shot
kevinbmx77
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
The base of my MC5200 was caked in EGR crud and never caught fire...but a good idea to keep them clean when possible...it does take quite a bit of buildup to impair the flow inside but once that is done...you will know it.
I agree with the rebuild idea...not that hard and there are many youtube videos on how to do it...read, watch and learn before taking it apart...there are some small parts that are easy to loose and that would put you in a worse position if you don't keep them and put them back the way they were...
I started taking pics of stuff like that in case I forgot something...so make your won video is a good idea...so you can retrace steps..
ericbphoto
16,761
Wellford, SC
3.0L
6"
That Berryman stuff looks like a good idea.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I like the little basket...not that I could get my carb in that can...but dunking smaller parts is a good way to clean them without making another mess...
85_Ranger4x4
17,976
SW Iowa
Tired engines dump oil in the air filter housing via the PVC system (the hose that goes on the oil cap connects to the air filter)
Scrape off what you can first, it will clean faster soaking and won't foul your carb cleaner as fast.
MXGerry
21
I just watched a video about that stuff cleaning carbon off pistons, looks like it works great
Seen a former neighbor done it, they works magically with fine result.
