Check Engine Light, 51 Erorr
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Is there somewhere good here to run through diag of check engine light codes? I have a miss/stutter (all original injectors installed after issue with aftermarket ones) now I am getting a 51 error code. Do I need the emissions manual off line?
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Code 51 says the ECT signal failed at the high end(approximately 5.0 volts)failure mode indicates -40Deg. F.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
thanks. So possibly failed coolant temp sensor/switch? Wouldn’t think that would cause a miss.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
It will run the engine like its on choke, I think? ECU thinks its cold.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
194 deg F should be .60 volts with 2.80 ohms
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Back probe the ECT with a DVOM when warm
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,558
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yeah... check ECT sensor connector for 5 volt reference first.
If good... check resistance across sensor @ whatever temp it is at... bounce that number off an ECT temp table.
Uncle Gump
Token Old Guy
13,558
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Is it like a dead miss... or a random rich misfire.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Random miss can gag on throttle and mostly go away. But low load/throttle input in gear falls on its face.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
4.68v key on 57.0k ohms across sensor, compare to original sensor, 58-59k ohms. Ambient temp (48 f ) this morning. I’ll trace down the signal output now.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
test the old one in boiling water. analog meter you can watch the needle move as the water heats up.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
See above just edited post comparing to original…
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Back probed didn’t have enough time this morning to get it up to temp but no volts out of the second pin so I will check original in water at op temp and see then get truck up to temp and compare if ok I’ll check signal wire back to ECU.
Uncle Gump
Token Old Guy
13,558
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
For reference...
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Thanks gump
