Bump stops???
BlueLighting1999
Des Monines,WA
What are Bump Stops? And what are they used for???
Andres629
11
Saskatchewan!
2.9 screamer
They are normally bit of rubber that are attached to your frame to stop your suspension from completely bottoming out. They help to not bottom out your shocks and blow them up, essentially.
BlueLighting1999
Des Monines,WA
So getting these should help me in the trials???
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
Only if you are banging the frame and suspension at full compression.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Usually with Fords TTB its hard to reach the stock bumpstops...and even harder when the vehicle is lifted due to the springs being so stiff. Unless your jumping it or planning on jumping it....
You prolly dont need em but some look cool and of you have a a lump sum of money accumulating in your pocket spend away.............
