Bronco II doubler build pics
7111127
Coweta Oklahoma
dumb ? i new 2 this stuff what is the reason for doing this?
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
You know how you put your transfer case in 4low? Well this makes it 4low on top of 4low. Awesome crawl ratio.
7111127
Coweta Oklahoma
ahhh so should invest in this when i make a mud toy then lol
disciplerocks
53
Evansville, IN
For mud, no not needed.
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
For a mud rig, this would be a waste of time, since you normally want some wheel speed. With my doubler engaged and the tranny in overdrive, I can barely hit 15mph! However, if you have a rock rig, control and crawl ratio is where its at. For a rock rig, hands down the best mod!
74bronco2
January 2012 OTOTM Winner
2012 Truck of The Year
Dayton WA.
4.0 Liter
low low idle
beluga420
March 2013 STOTM Winner
MTOTM Winner
2013 Truck of The Year
7
Quebec, Canada
2.3t
Hey congrats for the truck of the year win! I voted for yours I really like your truck man looks amazing :headbang:
lorro
Cordoba, Veracruz, MEXICO
CARBURATED 302
GNOSIS
I dont know
in this image wich shaft's I have to cut and put together?, maybe for you it's super easy, and logical but maybe too I dont understudd what I have to modify, and this kind of job it's really delicated, so I want to be really sure of what I'm doing. this is for a new proyect that Im thinking to do, but I already have an BRONCO II with dana 44, ford 9 302, np435 dana 20, arb rear. etc.
I imagine that are the numbers 58 and 81 that I have to cut and weld:icon_welder: together, but I'm not so sure, maybe if you can showme a pic of the 4x4 output shaft when is not already cutted, i would be very helpful to. maybe the image it´s to small but it took it from this page: https://www.google.com.mx/search?q=bw+1350&espv=2&biw=1920&bih=955&source=lnms&tbm=isch&sa=X&ei=gijyVKr6KYGWyATT94KoAg&ved=0CAcQ_AUoAg&dpr=1#imgdii=_&imgrc=xxXw4rJilfIRZM%3A;bvIT2inn2t2PEM;http%3A%2F%2Fwww.rsgear.com%2Fep-diagrams%2Fimages%2Fborgelectricalshift.gif;http%3A%2F%2Fwww.rsgear.com%2Ftechnical%2Fdiagrams%2Fep-diagrams%2Fborg-warner-1350-transfer-case-electrical-shift.aspx;575;684
btw this is my truck:
sorry if the image it's a little bigger that normal:dunno:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xpf1/t31.0-8/10922581_10204316336682410_1675665105856780924_o.jpg
If you have a Dana 20 like you say, then you're looking at the wrong diagram (sounds like your truck is very far removed from it's original configuration).
I believe the 1st-gen Ford Bronco ('66-'77) used a NP435 & Dana20 combo, so you would probably want to look at that application for yours since that is probably where yours may have come from. There are also replacement gear kits available for a D20 that will give you a deeper gear ratio.
Welcome to TRS. :beer:
