Bronco 11 front springs with a 5.0 swap
2 bronco 11s
66
kentucky
ford bronco 11
What coils springs are recommended with a 5.0 swap ? I here there is an alignment problem with stock springs. Thank You
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
I believe most guys run the stock springs. Your factory ones maybe just worn out and cant support the extra weight
2 bronco 11s
66
kentucky
ford bronco 11
Thanks. I guess I'll change them also. One other thing, are there any direct swaps other than Bronco 11 for the rear differential?
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
A 8.8 from a 4.0 ranger will work. But youre not really gaining much strengthwise. An explorer 8.8 is a common upgrade also but it requires flipping the spring shackles...but it does gain you some strength with having 31 spline instead of 28 spline axle shafts
Assuming youre gonna wheel it id be more worried about the dana 28 front axle then the 7.5 rear.
2 bronco 11s
66
kentucky
ford bronco 11
It's an 84 I'm staying with the C-5. I can probably find a 89-80 B11 with the bigger front rear end. What else is a direct swap? Thanks again
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
For axles? Thats all im aware of.
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
I'm doing this for my grandson. What do you recommend on the front ? Thanks
A dana 35 from a explorer or 4.0 ranger is what most guys use
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
2 bronco 11s
66
kentucky
ford bronco 11
I have a 93 Ranger 4.0 5 speed less the body here. It has a bent frame. Will this front end fit the Bronco 11? Or what modes will I have to make?
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
Rusty?
I'm glad to see you back...
In the flesh lol
It should yes. I think theres a few small mods you gotta do but im not to sure of the details...but its been done around here alot.
2 bronco 11s
66
kentucky
ford bronco 11
In the flesh lol
I'll do some research to see what I can find out. Maybe someone on the forum will let me know. Thanks for your help.
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
Elutheros
129
Central Texas
I put Skyjacker 2" lift coils on my 1992 and they worked great to put it back to stock height (old coils were dead) with the 5.0 swap.
2 bronco 11s
66
kentucky
ford bronco 11
Thank you. I would say these are too!
