pontiacfieroguy
- Jun 25, 2010
- 12
- oak ridge,tn
- 1989, rip1988
- ford
- Engine Size
- 2.3 4cyl, rip 2.9v6
I'm having a major problem with the driver side drum brake on my 89 ranger. the lever that works the adjuster wheel has broken twice. a little back story, po replaced shoes and line but broke bleeder valve, I went to put a new wheel cylinder in and when I pulled the drum off the hold down spring and crossbar spring were just sitting inside the drum, the adjuster cable, guide, and lever were missing as was the bottom spring. I bought a new hardware kit and a new adjuster kit. got everything put together and when I hooked the bottom spring to the front shoe and to the adjuster lever and hooked the lever to the rear shoe the lever broke where it connects to the shoe, I bought a new lever and it broke at the same place. I am installing the lever by putting a screwdriver through thehole that the cable attaches to and prying off the backing plate and as soon as the lever hooks the shoe it breaks. am I doing something wrong or did I by some bad turn of luck get to defective parts in a row.
