Boosting CB radio
CopyKat
8
Manitoba, Coldest place in Canada
Since installing my CB the range has only been about 2 miles.
Did I do something wrong with the install or is there a way to boost the signal?
There are no loops in the coax cable running to the antenna, any extra was zigzaged.
4 foot Antenna location is back by the passenger tail light.
BlackBII
Ranger Custom
Truck of Month
983
UT
I've heard the ideal length of a CB antenna is 15 feet....
Fx4wannabe01
February 2010 OTOTM Winner
20
Boring, Oregon
You antenna location SUCKS!! Move that thing to a front fender mount. That way it has a chance to actually span out.
You see....you have about 3' of body blocking that antenna from shooting out. imagine a triangle...with the point of the triangle at thebottom of your antenna, or the bottom of the antenna above your body.....you've got so much body blocking that antenna, that you can't shoot far out at all....I'm a little surprised you're pulling 2 mi out of it.
Fix that antenna location or get a taller antenna....moving it will significantly help. Taller not so much. There's no boosting that you can do to that CB unfortunately.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Actually the top center of the roof would be a much better place to put it.
Range on CB tends to be extremely variable depending on band conditions and whether you happen to be in an area plagued by noise (from power lines, neon signs, etc.). Anywhere from .5-25 miles is common with a stock radio (no amplifier). I would say a good average is 5-10 miles however, and you probably would have no problem achieving that by relocating the antenna to a better spot.
Also, you might want to eliminate the excess coax if there's a lot of it (stories you might hear about the coax needing to be some specific length are myths. All that's needed is enough to reach from your radio to your antenna, and that it has a good RF ground connection with the vehicle body).
Fx4wannabe01
20
Boring, Oregon
fender mount is second best to a center of roof mount and drilling holes IMO...magnet mount FTL. Thats why I suggested it.
5speedin2.3
May 2012 OTOTM Winner
Livonia, Mi
2.5L
Rofl. I bet my Wilson 5000 magnet mount would work better then just about any "fender mounted" antenna.
With just my radio I can talk 50+ miles on a good day. Now if I turn the power on, I can talk to people 300+ miles away. :icon_thumby:
Last week when the skip was rolling I talked to a guy in southern Louisiana like he was down the street from me.
Hell, My setup works better then my friends base antenna (antron99) and its 75ft up in a tree. :dunno:
Look it up, The Wilson 1000 and 5000 antennas are by far one of the better mobile antennas you can get.
Unless you want to run a monkey made or predator 10k. :shok:
Fx4wannabe01
20
Boring, Oregon
That's also a $100 antenna compared to a $20 4' glass one too....
Jason
28
(formerly) 200
You antenna location is all wrong. You have no ground plane. 2 miles is a blessing. Google up some CB info is you are concerned about the radio being functional.
5speedin2.3
Livonia, Mi
2.5L
I got mine with my discount. It was $90otd with 18ft of Belden 8x coax and a gold plated amphenol end. :headbang:
The stock coax on the Wilson5000 is good but it doesn't handle large amounts of power very well.
Then I paid $230 for the "box" and two jumpers. One 3ft jumper and one 6ft jumper. I also have over $80 in to my Cobra 25. The radio alone was $30(used).
I also have about $80 worth of microphones.
As for the base radio, I have an antron99 mounted on a tree outside of my apt and a Cobra29XLR hooked to it with a d104 lollipop mic.
Its all worth it IMO. I use my radios all the time.
If you're only going to use your radio to talk to other people on the roads (IE: a group of friends/rangers) then you should be fine with a Firestik and a stock radio.
Jason
28
(formerly) 200
What else would someone use it for? If you want long range you use HAM. Hell, I drive truck and don't use the CB unless I am scale spotting or a receiver tells me we are using it.
5speedin2.3
Livonia, Mi
2.5L
I talk to people all over SE Michigan with mine. There is also a large group of locals with CB radios.
Sometimes the "wars" can be fun, I learned the hard way to keep my nose out of it. :icon_rofl:
Getting chased down 96 doing 100mph isn't fun, especially when the person behind you is some crazy old guy with a sawed off shotgun. :shok:
Roadkill
Ontario, Canada
7.3l turbo
+1 :icon_hornsup:
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Yes the best location is centered top of vehicle but everything about an antenna system is a compromise.
You should be able to get satisfactory communications from just about any point.
The first thing I would do is a Power Mic.
Astatic has good ones, smaller ones like the Mobile D-6 is a great one, the Red Devil is the one I have and it is really good but bigger in size only.
Chk your SWR for the lowest setting and make sure you have a good ground from the antenna mount to the frame (not just through the bumper) and add a ground wire from the chassis of the CB (maybe a screw on the back panel) to a good metal ground location.
Run the setting on the Mic on the lowest possible setting for two reasons, one is to stop any squealing that can happen with Mic feedback and two adjacent channel splatter.
Power Mics are good but they can cause problems, nothing says you can't turn it up if you need to get out for some reason but be reasonable.
I am sure there are illegal ways to add power to the CB but the above is suggested as a good compromise.
5speedin2.3
Livonia, Mi
2.5L
But channel splatter is the part that makes it fun. :icon_rofl:
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
CopyKat,
How's this go'n ?
