rurouni20xx
- Jan 13, 2009
- 0
- natchitoches, la
- Ford
- Engine Size
- 3.0L V6
Okay on my 92 ranger 2wd extended cab 2.3 w/ the dreaded i beam front end...i have a problem i would like to rectify! when making turns and corners above 20mph my body on my trk rolls like you wouldnt believe, about 6 inches or so sometimes, and my rear end likes to sway (tire outside of wheelwell when looking in mirror...) i found the article in the tech library about the traction bars for the rear, looks promising and may have to try. my front end is whats puzzling me, i have the factory sway bar but you could have fooled my as to why its on there. i have thought about (and looked for) stiffer springs for the front end, ive only found load control springs on summit and not sure how much stiffer they are. i did the drift thing and such and i know stiffer springs reduce body roll and help w/ cornering, i would like to know there are any springs available on the market that are stock ride height and stiffer to help reduce this problem or if others have had this problem and how did they correct it. i bought the trk used and it did this since i bought it, the chassis bushings all appear to be brand new and the other components (ball joints tie rods sway bar end links etc) all look okay, the shocks are cheap and are prob on their way out and i plan to replace them, just want to fix all my problems in one lift of the jack if possible. thx for any and all replies.
