big problems with my 2.8
lil red
Firefighter
Dirty Jersey
i hae a huge problem, i am in the middle of rebuilding a 2.8 and have found that the fromt bolt into the crankshaft is missing, does anybody have the specs on this bolt or have one they would sell me?
i really need to get this truch done
also if anyone has any suggestions on how to remove broken off exaust manifold bolts from the heads or if you have heads you would sell me
near trenton nj
man i really wish my dad had just let me do the valve stem seals.....
Nipplechops
Airdrie, Alberta
2.3L Turbo
Are you talking about the bolt for the harmonic balancer? You should be able to pick one up from any specialty fastener place. You would have to know the spec of the bolt though. I can't recall what it is, but someone here should know. Any Ford dealer should be able to provide the spec.
Removing the broken manifold bolts shouldn't be too difficult. You need a set of drill bits and an extractor set which are both readily available from any tool store. Drill a hole down the middle of the bolt, tap in the extractor and twist it out. If it is stuck in there good, you can also just drill it out and retap the hole. Make sure you drill straight, otherwise you will drill into the head.
When I worked as a machinist, I found that welding a nut onto the bolt shank was the fastest and easiest way of getting broken bolts out. However, if the bolt is broken off below the machined surface, that isn't going to work.
lil red
Firefighter
Dirty Jersey
yes,that bolt
and iv tryed all of those methods exept drilling and re-tapping the holes, broken 3 extractors
BlackBII
Ranger Custom
Truck of Month
983
UT
Have you tried these? (they only work if the bolt is sticking out of the head)
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
just go to a hardware store and buy top grade bolts. thats what i did when i had to put new bolts on my fan clutch
Nipplechops
Airdrie, Alberta
2.3L Turbo
yes,that bolt
Then I would suggest drilling and re-tapping or taking the head to a machine shop. Broken exhaust manifold bolts are the worst bolts to break next to chassis bolts. :annoyed:
skippy
38
Georgia,USSA
2.8l durasparked rice killer
Machine shop and junkyard.
lil red
Firefighter
Dirty Jersey
have a set, bolt isnt sticking out anymore...
old boss welded a nut to it and it snapped off
Start with:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38180
Then look for "Kroil" the stuff is amazing. http://www.kanolabs.com/
be patient, it will work out.
I'd try a junk yard for that crank bolt.
ill deffinetly give that stuff a try, looks amazing
i dont know the size and therad of the bolt...., and the engine is german built and therefore mostlikeley metric
thats the next step.....
and why take them to a machene shop
thank you all,
bill:icon_welder:
Nipplechops
Airdrie, Alberta
2.3L Turbo
thank you all,
bill:icon_welder:
Most people (like myself) don't have the coordination to drill straight with a hand drill. Machine shops have jigs and such to line things up perfectly to gaurantee the hole will be straight. Luckily, I happen to have the equipment in my parent's garage so it saves me the trip to the shop. :D
sloue
Canada
302
i have 3 of those bolts you can have. pm your info see if i cant get it to you. i also have like 5 good heads ,well so so heads. you can have also but shiping would kill you
lil red
Firefighter
Dirty Jersey
my votec teacher says he can drill em out for me, and if he screws em up hes out a set of heads.....
i have all brand new grade 8 bolts to go in the holes, i just need the holes empty
O and does anybody have pictures of how to do the duraspark swap, i know i can get the carb and am buying a set of headers, but im kinda nervous
o and the motor is getting pulled sometime this week, and rebuilt in school for a grade. any tips on how to transport it im my other ranger, i was thinking set the oil pan in an old tire and tie it down real well
also, whats a good way to hold the trans up in the truck, my dad thinks a cinder block with a bottle jack on it, any other ideas:icon_welder:
Psychopete
29
FW, IN
That's worked for me.
Machine shops can work wonders with busted bolts. Actually busted the bolt off in my steering knuckle on my Tempo that holds the shock (yes I know, those are usually easy, not the case in my situation). Machine shop extracted it and I didn't have to do anything except get a new bolt for it and pay $23. If you have several that are busted, that could get expensive though.
Even busted a bolt off in a harmonic balancer trying to get it off with a cheap puller. They got it out no problem.
FWIW, If the 2.8L heads are anything like the 2.9Ls, some have drilled all the way through and used longer bolts with nuts.
Pete
lil red
Firefighter
Dirty Jersey
they are close to the 2.9
and idk of a machene shop close, o and moolah is real tight so she's gonna go slow
