Best front disc kit recommendations?
jungScipio
19
Nebraska
Mazda B2500
Hey all, I've been looking for a good front disc set for my 1999 B2500 SE. Most of the search results are for performance parts, and I don't tow heavy things or go offroad so I don't need anything beyond stock. Does anyone have front disc kits near oem that they'd recommend?
Blmpkn
Toilet enthusiast
6,428
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
If all you want is OE equivalent parts just head on down to napa or whatever your parts store of choice is.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,826
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
What Blmpkn said or get on Rock Auto. We post discount codes in the General Discussion section as we get them. They are only 5% but 5% less is better than no discount.
Anyway, Rock Auto will list brake parts by "Economy", "Daily Driver", "Heavy Duty", and "Performance". OEM tends to be either listed under economy or daily driver. Rock Auto, even without the discount, and after shipping tends to be cheaper than the local big box auto parts store.
mikkelstuff
470
Brighton, CO
3.0L
If you are up to it, I think you may be able covert your 1999 Ranger to 2004 front disks which are larger in diameter. At least I did so to my 4WD 2002 Ranger. Someone else will have to comment on application for a 1999 Ranger.
This does require changing out the steering knuckles which I obtained from a nearby salvage yard. I believe this also requires 16" wheels.
This change with new Wagner Thermo-Quiet ceramic pads definitely made a difference.
sgtsandman
Ham Radio Operator
12,826
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
If they are the factory 15" wheels, they will fit with the bigger brakes. I've had the steel rims as well as the aluminum rims that came with my Ranger and both clear 12" brakes but only barely.
