Bench Grinder Question
97ranger4x4
Sacramento
So I finally got a bench grinder. click me
I have a quick question. I see it has a coolant tray, but I am not really sure what its purpose is. can someone inlighten me? :icon_confused: I got a wire wheel for cleaning bolts so I am excited for that. :icon_thumby:
Thanks for your help.
Sunk
125
Everett, WA
3.5 Eco
For putting coolant in. :idiot:
I know some have them, and others don't. I've never used coolant.
BlackBII
Ranger Custom
Truck of Month
982
UT
Most likely it's there so you can cool yer crap off after grinding the hell out of it, as it tends to get rather warm :D
97ranger4x4
Sacramento
alright makes sense. I just pulled the tray out and was like hmm this looks kinda cheapish. Thanks for the info.
grey ghost
oil city,pa
2.3
the one that i have has one and i just put some plain water in it and use that to cool off my parts..
lil red
Firefighter
Dirty Jersey
ya, it so you can douce parts in there after grinding them allot, i havent used it ever, mostly because im too lazy to put water in it, but its not a bad idea, just dont use a glass of iced yea to cool your parts, it doesnt taste too good:)
Sunk
125
Everett, WA
3.5 Eco
I usually just take what I finished grinding outside and dunk it in a bucket of water or turn the hose on and give it a dousing that actually does something.
However, more often that not, I simply proceed to burn myself with it.
rangerbum
30
Kalispell, Montana
2.8l
When I Made a complete set of Cold chisels and Wood Chisels I used a really nice grinder with the nicest coolant holer. It was a good sized moveable dish that said "Dixie" on the bottom of it, made of some sort of paperlike material. Btw, I think Im going to jump in on that deal and get a new grinder for my garage. Thanks for the link.
97ranger4x4
Sacramento
Yeh I mean its no super expensive grinder but for cleaning bolts, sharpening blades it will work well for me i think.
woodyedmiston
4
Texas
Please, please, please hang a pair of goggles or a plastic shield on a hook above your grinder and use them. Many of my friends have eye injuries and one lost an eye sharpening the tungsten for his tig welder.
MAKG
19
California central coast
If you take hardened steel such as tool steel and grind the crap out of it, you can change its metallurgical properties. The coolant is to prevent that.
Annealing the tip of an HSS lathe cutter or drill bit sucks a** when you go to use it on steel.... You can use the coolant to quench it, or (better) to prevent changes in the first place.
97BlackBetty
Norman, Ok
Finally MAKG corrected most of you. You are suppose to keep the metal cool, if not you screw it up. When I am sharpening a bit or chisel, or really everything, I quench the object I am grinding every 2-3 passes. It helps to keep it cool, if you are getting the material so hot that it burns you, it is really no longer useful for its intended purpose.
MrE_Powers
12
st. chuck county, mo.
3.0,4.6,2.8
fyi dont dunk if it can wait you affect tension of what ever you dunk
