franklin2
- Dec 24, 2019
- 1,758
- Virginia
- Bronco II
If you think there is something wrong with the EGR system, a quick way to determine this is to take a thin piece of aluminum like a pop can, flatten it out and make a temporary solid block off gasket and slip it inbetween the EGR to block it off. You will get a EGR code from this, but all the computer will do is retard the timing slightly while driving down the road. You probably won't even notice it. If it doesn't help your problem, then you know to look somewhere else.It's the engine, it acts like a vacuum leak but I smoked the system to show nothing. Mounts are good, I'm thinking something with the EGR system.
