Are DEA and Anchor motor mounts garbage?
thcscubajohn
31
Antarctica
FORD
247ci
4"
31x10.50r15
Smog is for pussies.
Are solid 4.0 mounts from DEA or Anchor worth installing? I have the engine out ant the stock mounts are OK. However, they are 26 years and 160k miles old so I don't exactly feel comfortable not changing them.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I've used anchor mounts before on several vehicles and never had a problem. They always seemed OEM quality. This was years ago and the quality from many previously good companies has dropped significantly though (Like Moog).
19Walt93
4,466
Canaan,NH
351
3"
235/55R16
I've tried to use Anchor mounts on 3 different vehicle without luck. The hole to mount them to a 302 or 351 are mislocated so the mount butts up against the block and the bolts won't go in.
Junk Collector
Truck of Month
4,800
Rapid City SD
I just used 2x Anchor motor mounts, a transmission mount and a carrier bearing, 1992 Ranger application. Seemed to be decent quality.
Dunno about you guys but I have yet to see a broken motor mount on a V6 Ranger. The OEM ones are pretty stout. 4 cylinder, not so much.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I think that's a somewhat inherent problem to alot of inline engines. I've replaced more engines mounts on straight sixes and 4s than anything else.
