Anyone bought a trans cooler lately?
ford4wd08
510
Alcoa, TN
2.8 V6
I'm looking to install a bigger trans cooler onto my B2 with the A4LD.
I have the stock one from '85 which is a tube and fin model.
I was looking at this stacked plate design on amazon.
It says it is 11" x 11", that seems rather large, lol will this harm any air flow to my radiator?
I still plan on leaving the connection into the radiator from the trans.
duffy
19
Hot Springs, SD
Ford Bronco II
Mine has one about that size.......^^^^^ I didn't install it though. Seems to work well, I replaced the radiator (leaked) and use it as well as the added cooler. Took off the OEM fan and am using a 16" (3000 cfm) electric. Engine and trans seem to be cool.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I've read that stacked plate coolers are better and more durable.
ford4wd08
510
Alcoa, TN
2.8 V6
Finally got around to installing my stacked plate cooler today I replaced the stock tube and fin cooler.
I think it will cool well and the one I listed above is a great fit for the bronco 2, didn't even have to drill a hole to mount.
superj
2,577
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
you can usually find some nice ones at the pick n pull too. the larger ford vehicles are normally the place to go for transmission coolers
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
Make sure you flush it out really good though, secondhand blown transmissions from garbage in the cooler could be a bad day.
black_demon69
142
AZ
4.0l
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Why yes, yes I have thought about it. But not for a trans cooler. Interesting ...
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
That is the first time I’ve seen a cooler for a manual transmission. I suppose a old condenser core would work for that since manuals are as temp. sensitive as automatics.
For an automatic, I think it would be too much cooling and cause other problems.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I doubt there's a ford ranger out there that legitimately NEEDS a cooler for its manual trans.
K.I.S.S
black_demon69
142
AZ
4.0l
K.I.S.S
i would agree just thought it was interesting
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
