Any advice on how to bypass a/c from turning on during heat modes?
Flounder
4
Hilo, Hawaii
Ranger xlt
Hey Walt, Thanks. Yes I am aware of this and I use my a/c regularly throughout the year as I live in Hawaii.
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
My favorite solution is just keep the pedal on the floor. The wide open throttle (WOT ) relay will keep the A/C off.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Yes I recall on old Saabs in the user book it said run a/c periodically in the winter for just that reason. Suspect at that time they were not running defrost thru it, which would seem weird considering where they were made (most of them anyway) but there it is. Off-topic, but it also occurred to me that they had turbos early on, probably some of the first, if not the first, and they said when you stop, idle for about a minute to let it cool down. They did get hot, I remember if I ran out of matches I'd run the turbo a bit then stop at a rest area, open the hood, and light a cig on it. Fun times.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
AdjustableTemperatureSwitch, mounted under the Hood, set at roughly 50f\10c or so,
with CapillaryBulb located behind Grille, NormallyClosed contact in series with ACClutch;
could be a solution to automaticly prevent ACCompressor from engaging in cooler weather.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
Fords already have something like that built in. An override toggle switch is cheaper.
