always drain fluids before removing transfer case and transmission
Zapper
Yes i can afford this without "daddies money"
45
Buhl,ID
1986ish
ford ranger
2.294e+6 cubic millimeters
shot bushings?
235/75/r15
To send it or not to send it, that is the question.
this should be common sense which i do not have because i spilled 1/3 of the fluid in the tcase on me when carrying it, because i was trying to save the fluid that was in there but i guess that it decided that it wanted to be emptied by draining onto me. So i recommend that yall don't do what i did so you don't ruin your clothing.
85_Ranger4x4
17,833
SW Iowa
I tried that the last time I pulled the trans and t-case together. The whole works did a barrel roll on the way out and atf went everywhere... it worked ok the time before that. Probably won’t try that again.
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
So I must have been lucky when I did mine. Well, I did spill a little bit out of the speedometer cable hole.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Gettin dirty is 1/2 the fun....
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
and if you find a dirty girl...
well... that's a 100% fun
Josh B
1,986
Oklahoma
I've pulled mine twice in the last month, once for a clutch, then for a transmission. Drained them both the first time, but the second only the transmission. The transfer case didn't go far either one, but the second time I rolled a paper towel and stuffed it into the speedometer gear hole
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
yep... just like that
Zapper
45
Buhl,ID
1986ish
ford ranger
shot bushings?
235/75/r15
that speedometer cable hole is evil
