Aftermarket Harmonic Balancer
aussie280
5
Australia
Ford Capri
Hi guys
Can someone suggest an aftermarket harmonic balancer or how to measure what I will need?
Cheers Kev
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
Probably but we'll need to know what engine you're talking about.
aussie280
5
Australia
Ford Capri
I believe early 2.8s had one. Does anyone have a spare one for sale as in photo?
aussie280
5
Australia
Ford Capri
Sorry guys, I posted in 2.8 section. It's a 2.8efi cologne but it would fit all 2.8 cologne engines. I believe the crank is from a 4 litre as it's been stroked to 3.5 liters. The picture above is from early 2.8 cologne blocks possibly bronco or mercury capri.
Regards
Kev
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
Mixing rotating parts changes things, once you get a balancer I'd recommend sending the crank, rods, pistons, balancer,and flywheel out and having the assembly balanced. I could prove to be cheap insurance. Dorman makes a bunch of replacement pieces like balancers but I can't speak for the quality of their more recent stuff.
aussie280
5
Australia
Ford Capri
Hi Walt,
I appreciate the advice. My engine is balanced and blue printed. All of the 2.8s have dampers but are cast iron. I'm specifically trying to find the damper which is in the photo found on 1970 era USA 2.8 engines as it's a true elastomeric ring vibration damper. Its no good for the truck 2.8s without modification but good for me. Alternatively I can take my damper to a mod shop to have it weighed and measured to replicate for an aftermarket version.
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
It needs to be rebalanced if you replace anything, you realize.
aussie280
5
Australia
Ford Capri
Yes sir, I've spent alot on the rebuild so far and nothing is standard. Its being put together by an engineer. Hence asking about the part I need.
Blmpkn
Toilet enthusiast
6,370
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I've replaced stock crank pulleys with aftermarkets and certainly didn't tear down the engine and have the rotating assembly balanced, no Ill effects. Can you elaborate on your position? Is this something cologne specific or something?
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
If the engine was previously balanced like his the balancer, flywheel, crank, etc, most likely have been either ground or weight has been added so that a stock part would throw it out of balance. If everything is factory and you replace the balancer- for example- it's still going to be fine.
BrownRangers
49
Burbank, CA
2.8 V6
171cui
3"
These engine are internally balanced. What ever you ad front or rear you can have balanced individually to 0, then just bolt it on. I had my rotating assembly balanced to 0 then my clutch/flywheel balanced to 0 and stock crank pulley. Correct me if I am wrong?
aussie280
5
Australia
Ford Capri
Hi guys,
My engine has been externally balanced. I've since changed pistons so will have to get engine balanced again. Hmm
Oh well it is what it is.
Regards
Aussie280
