AC clutch engages when I run defrost heater...normal?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
When I slide the climate knob to defrost, and the temp knob to fully hot, the ac clutch engages. Is this normal? its a 4.0 OHV r143a coverted
franklin2
1,758
Virginia
Bronco II
Yes. When it's cold and rainy outside, it dehumidifies the air hitting the windshield and makes it clear up faster.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Thanks for the prompt response. This was while it was hot outside, but I figure you mean it comes on regardless, as part of the defrost setting (to dehumidify)...
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Anytime you go to defrost... they turn the A/C on to dry the air. Regardless of ambient temperature.
It's working as it should.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Thanks guys, perhaps I'm being paranoid after recent wrenching trauma lol, not used to things working as they should.
19Walt93
4,469
Canaan,NH
351
3"
235/55R16
It will run the compressor in the mix position as well. Years ago people in areas like NH would turn the a/c on in the spring and find the compressor seized because it hadn't turned in six months. Now the compressor is "exercised" during the winter and the defroster is more effective.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Ah that makes sense, although I would rather not have the compressor running unless I am using ac, I fund a heater setting that wont run it...did they save any engine to move truck? sheesh...
19Walt93
4,469
Canaan,NH
351
3"
235/55R16
So put a switch in the circuit between the heater controls and the compressor clutch power wire, or select Floor, Panel, or Off.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Copy that, I'll go with Panel lol
