A4LD Failure, Looking at M5OD-R1 Swap
chrisbronco2
6
Houston, TX
Ford Bronco II
Rare?!?! Ranger pedals are RARE?? That seller is a total chode. Those are not anywhere near hard to find nor are they expensive. Maybe $20-30 is what I would pay for a pedal assembly at a junkyard. '89 to '94 are all the same - Ranger, Bronco II or Explorer. Actually you don't even need the bracket, just the pedals themselves, they can be swapped without removing the dash... kind of a pain but doable.
Thanks. I wouldn't need the bracket on an auto-to-manual conversion?
Junk Collector
Truck of Month
5,264
Rapid City SD
Nope. The pivot rod is hold in by E clips on each end... remove the passenger side clip, slide the rod out towards the driver's side of the truck, then the pedals fall right out. Installation of the new ones is the opposite of removal.
I've done it several times, it's a bit more difficult on newer trucks because of wiring that is in the way and it helps to unbolt the parking brake pedal assembly for more room... but it's WAY easier than removing the whole dash.
Josh B
1,993
Oklahoma
A donor vehicle is always the best option, next up would be scavenging at a wrecking yard
Facebook marketplace is a good place to start
RobbieD
2.9l Mafia
4,005
Georgia
As said, it is MUCH easier to change out the pedals into your existing bracket. You can also get new plastic pedal shaft bushings in the "Help" section at the parts store, and end up with like-new pedal operation to boot.
The eBay deal looks "convenient" but way too expensive. It looks like the seller "restored" the pedals with black spray paint; all the brackets I've seen are natural cast aluminum color. That's kind of a "red flag" to me.
As also said, a donor or a junk yard is a much better option. Seeing the donor parts in place, and especially removing them yourself, is very valuable experience for when you go to put them into your own truck.
Otherwise, to answer your question, if you get the eBay deal, you'll need to get a triple-function switch and it's mounting clip, and make sure that you get a new master cylinder that includes a new rod that will clamp onto the pedal stud (most do, I think). The eBay unit is also missing the rubber pads (likely get 'em from LMC, but at yet more expense). And do the new bushings.
Glad to see you looking into doing the swap. Hang in there.
rdn10se
TN
Hello Chris, Rick from TN here. If you do the swap, would you be interested in selling the fill tube and dipstick off your old A4LD?
chrisbronco2
6
Houston, TX
Ford Bronco II
Hi Rick- I'm not doing the swap after all. Don't have time to hunt down all the parts. Getting the auto trans rebuilt.
Josh B
1,993
Oklahoma
I think it might be possible to make one, it's only a tube and a stick. I am not attempting to be sarcastic here, I know it must fit only where it belongs, with no part interfering with others, I just think, even for temporary purposes that it can be very possible to construct something that provides the information you need from one, even if you have to begin the process with a fresh oil change to ensure you are starting with the correct full level
TexasDuck66
July Truck of The Month
25th Anniversary Merch
