99 Ranger 4.0L connecting rod bearing clearances
Robr
Stuart,fl
Having problems getting the correct allowable connecting rod bearing clearances for my 99 Ranger 4.0L OHV, don't know if that makes a difference. The VIN is X. Any help would be appreciated. Thanks in advance.
Uncle Gump
Token Old Guy
13,465
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Are you just trying to replace std. rod bearings?
Was there any machine work done?
Did you measure the rod journal?
Robr
Stuart,fl
I haven't done anything yet. I just want to know clearances so when I measure I know if I need under size or not. I have one that's a little noisey
Uncle Gump
Token Old Guy
13,465
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well I read that wrong...
If you truly have a noisy one... you will see it. And at that point the crank will need to be machined.
I might suggest you pick up a service manual... factory manuals are better and can be had on CD or .pdf reasonable.
I don't have those specs in front of me... maybe someone has them... but I would guess around 0.002 -0.003"
Oxxon
51
Brownsville, Tx
Hello and welcome to TRS!!
