98 Ranger 3.0 2 weird ticking noises
gli7ch556
Kentucky
Ford Ranger XLT
Good afternoon all
Just got done replacing the cylinder heads and all other gaskets on this truck. The passenger side head gasket was blown. Drivers side was fine. The truck starts and runs, no CEL, but is lacking power and has two different ticking noises coming from it.
The constant ticking I think may be the PCV valve, thought uncertain. There is also a non-constant tick/ping that almost sounds like the AC compressor coming on, but it wasn't.
Any ideas?
Thanks in advance!
gli7ch556
Kentucky
Ford Ranger XLT
Also forgot to add, after hearing the noises, I popped the valve covers off and confirmed all of the rods are seated correctly and no bends or smashed ends.
187K on the Odometer
Things I have replaced/repaired on it so far(before the ticking noises occured)
Cylinder heads completed with valves, springs, seals (used existing rocker arms)
Cylinder head bolts
MAF Sensor
Camshaft Positioning sensor and synchronizer
All gaskets (Fel-pro master gasket kit)
EGR Valve
PCV
Injectors
Spark plugs
Coolant flush (brown goo, took about 3 hours to get it all out)
Water pump (brown goo tore it to shreds)
Thermostat
gli7ch556
Kentucky
Ford Ranger XLT
OK, did some further diagnosing today and have determined its something with cylinder 3. When disconnecting the cylinder 3 wire from the coil pack, the noise goes away. I'm wondering if it's something with the reman cylinder head I purchased and installed. Here is a better video of the noise, and it stopping when the wire is pulled.
Premature detonation? valves not opening? I'm at a loss as to what it is.
gli7ch556
Kentucky
Ford Ranger XLT
*FIXED*
More than likely it was me rushing and not double triple checking, but one of the rods was slightly off center. Aligned it correctly and it’s all good now.
