98 Explorer SOHC - rough running, need help
SolidSnake84
Stephens City, VA
Hi folks,
My wife's 1998 Explorer 4.0 SOHC, 4X4, just hit 170,000 miles a few weeks ago, all was well up until that point. The engine runs smooth, has no motor noises at all. Still plenty of power, and it doesn't leak oil or use any fluids. Now that cold weather has arrived, it seems it has developed some issues until the engine warms up:
Rough idle when cold - motor starts up, revs up to about 2,000 RPM, then stumbles, motor bucks and shakes below 800 RPM, and has a surging idle. This will go away in a few minutes as the engine gets warmer.
Cannot accelerate beyond 35 mph - even with pedal floored, the motor has no power and cannot get beyond 35 mph. The engine is not revving high, but quite the contrary - you cannot get the RPMs past about 1,800. But be ready, with the pedal on the floor, when the motor finally "catches", it will chirp the tires and throw you back into the seat from the sudden acceleration.
No codes from the engine during any of this. I verified that the check engine light does work, its just not throwing codes. Here is what I have replaced so far:
Plugs & Wires (Motorcraft)
MAF Sensor (Motor Craft)
IAC Valve (Napa)
Throttle Position Sensor
Camshaft Position Sensor
Friends are telling me I need a new EGR Valve - one guy says his explorer did the same thing and it ended up being the engine ?!?!
What do the "experts" on here think??
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Have you checked the injectors, what's the fuel pressure doing? Could be fuel pump or dirty injectors. Things that don't throw codes are a pain to fix. Carbon buildup on EGR or cat may be clogged too. Have you put any cleaner through the fuel system? Just throwing some ideas your way.
TxGasRacer
SE Texas
4.0 ohv
Almost sounds like a stopped up catalytic converter
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
A stopped up converter would not, "But be ready, with the pedal on the floor, when the motor finally "catches", it will chirp the tires and throw you back into the seat from the sudden acceleration."
Does it ever get well without the peddle on the floor? The computer ignores all the sensors with WOT so it will not set codes. It just dumps as much fuel into it as the injectors will flow. So low fuel pressure would really make things bad (lots of air, no fuel, you get the idea).
I agree, check the fuel pressure, no or low pressure, no go.
It sounds like maybe the pump is sort of intermittent. It finally does its thing and away you go. On my 02 Ranger 4L, it would idle low on cold start and then get well (until it died completely). If the engine gets below about 400 rpm the computer will shut the pump off for safety; but, it does not monitor fuel pressure (sort of like if you have it, good; if not, it won't run and you will figure it out).
Oh, and I'm no expert!!
SolidSnake84
Stephens City, VA
Yes - it does "get well" if you let it warm up 10-15 minutes before driving it.
All of the above mentioned problems happen when cold.
We are leaning towards the intake gaskets being bad, but have no way to really prove it. With engine cold, spraying carb cleaner, etc, around the intake area has no effect.
It has been to dealerships and hooked up to the various machines, etc, and no one can diagnose what it is. I have been told by some to just 'live with it", as there is no real way to diagnose the problem. We have been going the replace parts route, and so far not much left to replace.
Living with it might be the best option because like i said, it runs perfect and great when it gets warmed up. Just with cold temperatures it is a bear to start and keep running, until it warms up....
