MAKG
- Aug 7, 2007
- 19
- California central coast
- Ford
- Engine Size
- 4.0L
It's not the plenum (aka upper intake) because that's not going to hiss for two seconds after shutoff. Unless that was a red herring (A/C). About the only vacuum systems that can do that are leaky check valves, vacuum reservoirs, or vacuum motors (or the lines between them). Your power brake booster is one of these. Your climate control is another. Some EGR control circuits do this, but I think yours is electrically actuated. It can't be the intake manifold itself because it leaks down one volume of vacuum at idle in at most 2 crank rotations (if it didn't, you wouldn't be able to idle the engine). That's about 10 times faster than you're reporting (I calculate 150 ms for 800 RPM idle -- and assumed intake volume is about equal to displacement, as is common).
