94 Ranger xlt overheating issue
94fordheadache
9
Pennsylvania
Hey guys getting desperate at this point was looking for some advice. Have a 94 ranger 4.0 that keeps running super hot. So I started with the basics, changed the thermostat, the radiator had a slight leak, so I replaced that too.went ahead and replaced the radiator cap while I was at it (because for some reason a brand new radiator doesn’t come with a cap), still running hot. Went ahead and replaced the water pump that looked to be the oem from 94 STILL running hot very close to red lining on the gauge. I also have decent heat in the cab of the truck. So I’m just a little lost and looking for any insight on what I can try to tackle next. Also to add I’m quite sure I burped the system adequately.
Josh B
1,988
Oklahoma
Any chance the gauge is off ?
If not there may be something clogged somewhere
94fordheadache
9
Pennsylvania
I guess I haven’t checked to see if the gauge is accurate, but it even smells hot if you know what I mean. And are you thinking a clog in the engine itself? Almost all part in the cooling system are new except the heater core so I’m not sure but I don’t think any of those units would be clogged
Josh B
1,988
Oklahoma
Man, that's all I could think of :/
My first thought was a clogged radiator but then realized that couldn't be it
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
It could be a bad sending unit. But if you say you think it is actually running hot then maybe not. A clogged heater core wouldn't make it run hot so don't bother changing that! It's not an easy job!
rumblecloud
1,136
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Have you checked the temperature difference between the top and bottom radiator hoses?
Have you flushed the system - especially the heater core?
Reversed the heater core hoses?
Temperature sending unit?
Temperature sensor?
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
Saskatchewan...hard to spell...easy to draw
Is your fan shroud all good?
superj
2,732
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
is it slowly losing fluid each time you drive? and no sign of it going anywhere?
get one of those kits and check the headgaskets too. the ones you put on top of the radioator opening and pour the fluid into so it measures the fumes from the radiator. they are like 40 or 50 bucks but it will tell you if you have a headgasket leak and its just not "bad" yet. i have driven on a blown headgasket that wasn't "bad" for over a year on a previous car
welcome to the site, also
Junk Collector
Truck of Month
4,870
Rapid City SD
You need to get an actual temperature reading instead of assuming the gauge is accurate. IR temp guns are about $20 on Amazon or at Harbor Freight. Use that to check the temp of the heads, lower intake, block... should read no more than about 200 degrees +/-. Is the coolant boiling out of the radiator into the overflow tank? Losing any? Steam from the exhaust that smells sweet? (hard to tell this time of year.) Engine oil that looks like chocolate milk? Any other issues with it running abnormally?
Josh B
1,988
Oklahoma
stick a cooking thermometer into the radiator
94fordheadache
9
Pennsylvania
I’m not losing coolant and the top hose is hot and the bottom is not very warm at all. I’ll need to buy a IR gun to get more accurate. I’ll do a cooking thermometer later today in the radiator. It shows no signs of a bad head gasket except the over heating. Oil looks fine, white smoke stops after it warms up its 20 degrees here, no bubbles in the radiator or overflow.
94fordheadache
9
Pennsylvania
Also thank you for all the advice I have a lot more insight on what to look into you guys are awesome
superj
2,732
ranger edge
none
none
235s
Does it stay normal while idling but go hot while driving?
I ask because that can be a collapsing coolant hose happening when the water pump reaches a higher speed.
superj
2,732
ranger edge
none
none
235s
The thermostat has one of those wiggly deals in it that goes at the top when you install it? Or it had a solid plate?
Josh B
1,988
Oklahoma
Those last two are very good questions 94. The bottom (return ) hose should have that spring-looking thing that keeps it from collapsing when the thermostat opens and the pump is pulling water through it.
The thermostat too is a good question and it must be right side up, and right side out, for it to work.
Both very easy to miss if there's anything else on the mind
