2.3L ('83-'97) SOLVED: '94 Ranger not pulsing #2 and #3 injectors
frozenrabbit
4
ohio
'94 Ranger, 2.3l spark confirmed at all plugs. Will start and run, but #2 and #3 are not getting fuel. 12v at all injectors. Can pull #2 and #3 at idle with no change in idle.
SenorNoob
632
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I would suspect the wire connecting them to the PCM. It should be white connected to pin 59 of the PCM. That's injector bank 2.
frozenrabbit
4
ohio
White wire has continuity from #2 and #3 to PCM connector. Only OBD codes I am getting is from deleted ERG, 335 and 558.
Probe light on white at #2 and #3 injector connected to battery (+) does not flash. Stobes when hooked to #1 and #4 while rough idling, like a NOID light.
Originally cut out when driving, lowered rpm and they came back on, then out again with rpm increase, then just stopped pulsing completely.
Swapped around injectors, #2 and #3 work when installed to #1 and #4. Swapped between 2 ICM modules, no difference.
Failing PCM, or crank sensor? Replaced crank sensor 3 or 4 years ago, but when the old one was failing it was a complete no start. Confirmed spark on all plugs.
frozenrabbit
4
ohio
TPS tested within voltage range. ICM has 12.4v from ground pin to battery.
Crank sensor is at 9.17v, off and on with engine rotation.
Cylinder ID sensor is at 8.78v, off and on with rotation.
Going off of tests from this link:
Says CKP and CID should be 10-12v, but doesn't say anything about being under 10.
DAYUM!!!! I think I'm gonna go in for the crank sensor, already know it's a P.I.T.A. job, but need to do a front crank seal anyway.
Anyone run into this? Does hard start and run on #1 and #4, spark to all plugs, but not switching between injector banks, no fuel to #2 and #3.
frozenrabbit
4
ohio
Not the crank sensor, just replaced it today.
RobbieD
2.9l Mafia
3,606
Georgia
Good catch.
frozenrabbit
4
ohio
It could of age cracked, there's heavy spring clips that hold the mosfets against the housing. '94 with 370k miles.
SenorNoob
632
Middle Tennessee
245-70-R16
frozenrabbit
4
ohio
Couldn't find this issue anywhere on this forum, or any where else. Found a youtube video for a BMW with bad mosfets.
