94 ranger BW1354 electric to manual t-case
bnichols04
i have a 94 ranger with a electric transfer case and i want to convert it to a manual case. I see that mine has the BW1354 electric transfer case. Can i just get a BW1354 manual case out of a junk yard and swap them? i know i will need the shifter and stuff like that. I have read that the front drive-shaft needs to be shortened by 1" with the 1350 case will i need to do this with the 1354 manual case? Does the 1354 manual case have a hole for the speedo like the electric case? thanks for your help
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
You will need the shifter assembly for the transfer case. It is a direct swap for a BW1354 electric to a BW1354 manual. The BW1354 manuals have the speedo cable hole.
If you use a BW1354 transfer case, then you wont have to shorten the front drive shaft. The only difference in the BW1354 electric and manual is how it is shifted.
BlackBII
Ranger Custom
Truck of Month
984
UT
You may need to either get the correct floor plate or just cut yours, so the shifter will have a spot in come up into the cab! :icon_thumby:
Also get the shifter boot.
It is a pretty easy swap. 4 12point 12mm Driveshaft bolts, 5 1/2" Tcase bolts, drop the old one out and he man the new one in. Make sure you get the two bolts that hold the shifter assembly on to the tranny.
bnichols04
what is the most common ranger year that i can get a 1354 manual? i am guessing that the explorers have them too?
BlackBII
Ranger Custom
Truck of Month
984
UT
I've seen most in 90' and up Rangers and Explorers, Explorers will more commonly have the Electric case. But there are some manuals out there, look in Explorer Sports specifically.
bnichols04
it would be from 90-95? i have read that on a explorer that there is a plate that bolts in to the floor for the manual shift transfer case is this the same for rangers?
mjonesjr
Firefighter
13
Salem, IN
It is the same for every RBV.
TRX501RYAN
do the 4x4 lights still come on when you do the swap, also is the 4x4 elec sich eliminated in any way when doing this ?
04 EDGE
Banned
--- Banned ---
Westland Mi
you will have to re-wire the 4x4 lights.
there's a switch on the 1354M that you will have to run the proper wires to.
all you will need to do is unplug the 4x4 module
TRX501RYAN
good stuff, do you just re route the wires from the 4x4 module to the new man t case,
i have a stock bezel around to replace the 4x4 module and not even see it if i do the switch, im gonna search around see if theres a write up on this
shadow905
San Antonio, TX
3.0L V6
let me know when you do the swap. i will be doing the same thing here very soon in my 01 and i want to see how smooth it goes.
Beef52751
13
Eastern Iowa
2.9
did you get the swap done yet??? im very interested, if i do it, i think i will rewire the 4X4 shift knob to control my fog and offroad lights so it looks stock.
Beef
