94 B4000 with A4LD- drinks ATF
dreymeek
Hillsboro, OR
Mazda
4.0 v6
The Cobbler's children go barefoot.
No sign of any fluid leaks, but I regularly have to add ATF to the trans. When I got it, It had sat for 2 years. The level was fine, but one day it wouldn't move in reverse. I ended up adding 2 quarts and all was good. 1000 miles later I added another quart. This morning I checked it after driving it and I added a pint. NO sign of leakage. Where could it go?
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Does the a4ld have a modulator valve? I've heard of the diaphragm rupturing and engine vacuum sucking up atf on older trans.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
a4ld? smokey a bit i assume....
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I don't know where I got e4od, edited my original post....
Josh B
1,987
Oklahoma
If it's burning excessive oil you might check the tailpipe too, wipe inside it and see if it leaves smoot on your finger
dreymeek
Hillsboro, OR
Mazda
4.0 v6
I originally had E4OD as the trans type. It wasn't you! I have a modulator on order, we'll see how it works out.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I was gonna say goblins? :dunno:
RobbieD
2.9l Mafia
3,515
Georgia
Good chance that it may be the modulator. A while back my '84 with the C3 trans also needed ATF added regularly, but with no visible leaks. Had me stumped, until I finally noticed that occasionally it would put out a good-sized cloud of white smoke out the exhaust. Pulled the vac hose off the modulator, and ATF dripped out. A new modulator stopped the ATF leak and the white clouds. Hope the new modulator takes care of yours, too.
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
If it's a 4x4 check the transfer case fluid, I've seen the rear trans seal leak fluid into the transfer case. Another thing to check is to see if there's atf in the coolant. If it is a leaky modulator make sure you blow out the steel line and replace any rubber hoses that were exposed to the fluid and any rubber plugs on the vacuum tree if the line connects to one.
