92 Ranger 4WD Conrtol Module Location - Regular Cab
Deppdog
I have a 1992 Ranger regular cab. Can someone point me to where the 4WD Control Module is located? Thanks in advance!
Deppdog
krugford
Iowa
IIRC, it should be bolted to the back wall behind the driver's seat.
92MiniMonster
Baltimore
FORD
i just took mine out to inspect it, it is behind the drivers seat covered by a plastic peice the same color as your interior, the cover is held in by two 12 mm nuts and the module is held tight by those same two nuts, all you should have to do is pull it straight off of the bolts. i know youve probably already done this, but its late and i was in the mood to add detail.
