92 ford ranger 3.0 help please ?
Mando1818
Illinois
Ford ranger
I'm trying to pin point the issue with my ranger, its being stalling on me, already clean the MAF, IAC, replace the ignition module, TPS, fuel pressure regulator, fuel filter, fuel pump(wasn't holding pressure),plugs, wires, distributor and nothing seems to help...engine light keeps coming on and off, I don't know if the timing chain could be the issue of the stalling or something else....does anybody knows or got and idea what could it be...I hope to get some advice before Saturday bcuz already set my mind to replace the timing chain...??
gungfudan
19
Mississippi
Mazda
N/A
N/A
What was the Fuel pressure holding at? The fuel pressure should be between 30-40 psi.
Did you chang the coil as well?
Is it stalling while idling?
Is it popping any when stalling?
rusty ol ranger
2.9 Mafia-Don
7,604
Michigan
177 CID
Go to autozone and buy a 30 dollar EEC IV reader.
Pull the codes. Im sure theres a few in there.
Yes a timing chain can cause stalling, but once it stalled cause of a timing chain, it would not restart.
Mando1818
Illinois
Ford ranger
I think my fuel pressure wasnt really working well, but everyr.time I pressed the valve on the fuel rail to see if it had pressure and it didnt even with the key on..forgot to mention I did changes the coil..stalls while idling and sometimes it pops too..
gungfudan
19
Mississippi
Mazda
N/A
N/A
If its popping you might want to check into the ignition module.
rusty ol ranger
2.9 Mafia-Don
7,604
Michigan
177 CID
You pull the codes yet?
rusty ol ranger
2.9 Mafia-Don
7,604
Michigan
177 CID
Can he pull codes on a 92? With and OBD2 reader?
No....
But for 30 bucks you can buy an EEC IV reader. Its pretty nice. I bought one for my 87.
Or you can use a voltmeter. Instructions are on the main TRS page.
But id still reccommend the reader
Mando1818
Illinois
Ford ranger
92 is a obd1 ...I just did last night, at fisrt gave me a lot of codes and tben I did it again and only gave 2 codes I think it was 159 and 10...but need to check it again. Bcuz the code reader did not saved them just to make sure.
Mando1818
Illinois
Ford ranger
No....
I bought one of them...I'm going to read it again for the codes.
gungfudan
19
Mississippi
Mazda
N/A
N/A
No....
Dang wish I would have found one of those a while back
