- Apr 22, 2014
- 157
- Ohio
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- 2WD / 4WD
- 4WD
- Total Lift
- 3in
- My credo
- Clean your room before you criticise the world.
i came up with an idea that i need some opinions on i have a buddy with a zf 5spd thats got less than 100k on it with the t case which is bigger than my stock 1354 m-shift that i have now . i could prolly get for 120-150 and just swap that in there to get rid of my current trans problem but im not sure if it would be worth all that work to swap it over.
i do have a flywheel for a 5.0 to use brand new but i also would have to have my d shafts custom made which im going to need anyway after swapping my axels out to half tons.
Or instead of doing that i could take it to a local trans shop and have them go through it and help me set it up the right way but id still have the stock t case which im not sure would stand the abuse of a 302.
all advice is appreciated and considered im back to the drawing board here....thanks..josh
