87 bronco 2 no spark
Levisatadad
Troy in
Ford bronco 2
My son bought a 87 bronco 2 not running. We can't get a spark
Changed
Distributor and module
Coil
Plug wires
Ecm
Ignition switch
Fuel pump relay
Inertia switch is bypassed
Pumps come on. Cranks
good. Power to the coil. No spark
Levisatadad
Troy in
Ford bronco 2
Also replaced cap and rotor
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,687
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Sounds like a possible ground problem. Check the grounds from the engine to the frame.
Also, verify if it’s a ground problem by grounding a removed spark plug to a body bolt. Just make sure you take steps not to get shocked. Like a rubber glove and make sure YOU aren’t grounded.
Levisatadad
Troy in
Ford bronco 2
I pulled the coil wire and put a screw driver in it and grounded it. Nothing
sgtsandman
Ham Radio Operator
12,687
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Sounds like the new coil might be bad. Was it the same with the old coil?
85_Ranger4x4
17,908
SW Iowa
Check connector to coil for overall condition and make sure it is getting power/ground too.
Levisatadad
Troy in
Ford bronco 2
Yes both coils act the same
1990RangerinSK
1,312
Saskatchewan, Canada
Changed
Coil
Plug wires
Ecm
Ignition switch
Fuel pump relay
Coil wire. That's where I would go next.
