SHE RUNS AGAIN!!!!
I swapped out rotors and it got the job done. Timing needs to be adjusted but I ran out of daylight and don't have much of a bright spotlight to do it. Thank goodness the weekend is coming, hopefully I can get it done then.
I noticed that it is running a bit hot and heard a little sizzling when I finally turned it off. My thought is it's the oil/whatever else build up on the exhaust manifold. I'm pretty positive that my valve seals are crap so I plan on replacing those soon. Just wanted to get the thing running again before I did. Anyways, like I mentioned, it's seems to be heating up very quickly. Any ideas as to what should be inspected first would very helpful. Thanks!
franklin2, I got all of my parts off of RockAuto for the 79 mustang and they came in within a few days. Due to me ordering the wrong distributor (Bosch) I went out and bought the one listed in the how to from Orielly's and it was in in a couple of days. I plan on returning it unless someone tells me I should use that instead of the one I used. I took off the cap/rotor and replaced it with an adaptor, dis. cap and new rotor. Actually starts now.
Where did you buy your wrong distributor? I looked on rockauto and they do not have any, you have to send yours in to get rebuilt.
On the running hot thing, the 2.8 is a strange engine to me. I had to replace the waterpump and never messed with an engine with such a weird looking waterpump and with the thermostat in the lower hose and in the water pump at the same time. I did what I normally do when I fill an engine after draining it and when I got it going it overheated badly. My normal procedure it to leave a heater core hose off, and fill it till it runs out of there and then put that back on and fill it to the top and go. Not this engine.
I finally found the factory procedure, you are supposed to take the large upper radiator hose off the engine, and pour coolant directly down into the engine from there. Then put that back on and fill it the rest of the way. I thought I had ruined my engine but it survived and runs well,, though it doesn't have near the power the 2.9 has.
That is why I was asking about your distributor. I am looking for another duraspark 2.8 distributor, I haven't found anyone who has done it, but I want to try and retro fit one into the 2.9 I still have. If I could get the distributor in place, and then fabricate a intake manifold, I bet that little 2.9 would really run. The way it acted before when I had it on the road, I bet it would even take a 600cfm holley with no problem. But I could try the 2150 2bbl also. That engine ran well and didn't use a drop of oil.
