8.8"
Nehring13
Waterford, Wisconsin
ok, so since im new to axles and such, i have a 98 ford ranger 4x4 3.0 w/ a 5 spd. 373 gears, do i ahve an 8.8 or no?
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
Yes you have an 8.8, 28 spline.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Check the axle code on your door sticker (you can look it up here).
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
With a 3.0 I'd bet it's a 7.5...
Nehring13
it is only a 7.5. thanks guys. but i want to put in an 8.8. i hear you can get them out of an explorer and newer ones have discs in the rear. should i go with an explorer 8.8 or a ranger 8.8?
85_Ranger4x4
17,985
SW Iowa
The 27 spline Ranger 8.8 is a bolt in, you will have to weld some things on the Explorer axle to get it to work. The FX4 Level II trucks use a 31 spline with drums and a Torson differential, but they are pretty rare to find used but should also be a bolt in should you stumble apoun one. Unless you do alot of hard wheeling or heavy towing the 27 spine 8.8 should work fine though.
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
28 spline you mean. no worries, i always confuse myself between 30 or 31 spline.
85_Ranger4x4
17,985
SW Iowa
Yeah 28, not sure where I got the 27 from. :icon_confused:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
