4x4 to 4x2 comparison, differences?
Natedog
5
CA
On my 87 Rangers one is 4x4 and the other is 4x2, which of the following parts are different? Tie-rods and ends, steering box (I know pitman arm is different, but what about the box itself?), brake calipers, front and rear springs?
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
tie rods i am not sure steering box is the same calipers are a maybe along with the front springs rear are the same just with a 2 inch block added
Natedog
5
CA
Cool, how bout the brake master cylinder?
baddis
6
Avon,il
2014
masters are the same unless the 4x4 is an stx. wtf is up with a $62 difference in prices between 4x4 and stx 4x4?
Natedog
5
CA
More good news that I can use alot of my new parts off my old truck on my new old truck. :) :) :)
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Only difference on the steering box is the pitman arm. The 4x4 has a slight drop in it.
85_Ranger4x4
17,906
SW Iowa
I think the box itself is the same all the way up to the F-450.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
It is, but the pitman arm will definatly need to be changed. The master cylinder will be the same also, as long as the years are the same.
MAKG
19
California central coast
I suspect the steering linkage may be a (slightly) different length in that generation. If you look at how they are assembled, 4x2s tie rod ends go in from below, while 4x4 tie rod ends go in from above. I also believe that one can (usually) compensate for this with the toe adjusters.
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
I don't believe that they are the same, but they are similar in size and the 250+ box can be put in a Ranger as an "upgrade".
85_Ranger4x4
17,906
SW Iowa
Napa's website calls for the same power steering gearbox for the the Ranger up to the F-350 which is as high in the F-Series as they go.
