4x4 switch not working
ttscooks10
4
hi,i have a 98 ranger 4x4.i turn the 4x4 switch from 2wd to 4wd high.it clicks a few times.and the 4wd high and 4wd low lights flash on the dash a few times and then off.the lights flash again intermintally going down the road.any ideas?thanx tim
fastpakr
2,849
Roanoke, VA
The switch tells the GEM to request 4x4 High, Low, 2wd, etc. At that point, the GEM applies power to the motor and waits for continuity across the appropriate set of contacts at the transfer case confirming that the shift was successful. It sounds like the switch and the GEM are working, but that the shift motor is unable to move the transfer case linkage properly. I'd pop off and confirm that you can shift the case (pliers will work for that test), then clean up everything behind the motor to ensure it can do its job as easily as possible.
ttscooks10
4
great thanx.what do I need to pop off and where is it located?
fastpakr
2,849
Roanoke, VA
Sorry, meant to say pop off the shift motor on the transfer case.
planeflyer21
19
Sonoran Desert
I had the same issue on my '99 Ranger 4x4.
Fastpakr is correct, pull the shift motor.
I pulled mine apart and cleaned all the switch contacts and other gunk while in there, then sealed it with RTV before reinstalling it. Works now.
Still looking to ditch the motor and do a manual selector conversion.
jz78817
Detroit, MI
if you have or know someone who has access to a code reader, do a scan and see if code P1867 pops up. I have this issue with my 2011; the code means "Transfer case contact plate general circuit failure."
from what I've been able to find, the contact plate closes a circuit to tell the control module that the transfer case has been successfully put into 4WD, and if it doesn't see that feedback it'll go back to 2WD and set that code. I usually can get it to go into 4WD after a few tries. supposedly if you go for long periods w/o using 4WD the contacts can get dirty or corroded and won't reliably make continuity.
when it warms up I'm going to crawl under there and do what they said and try to clean it up.
ttscooks10
4
I pulled the old motor down.i turned the switch to 4wl.clicked a few times and 4wl light on dash flashed on and off.so I went ahead and got a new motor.the old one has a black wire going into the end of the transfer case.the new one doesn't have it.what is this wire for? I spliced it and by passed the plug. installed new one ,turned the switch.no clicking but 4wl light on dash still flashing.went for ride .stopped tried switch,still not switching on.4wl light still flashing intermittingly.dash switch?thanx tim
ttscooks10
4
took a couple days after I changed the motor,but it switches to 4wd high but something clicks under the truck when I put it in 4wd high and drive.sounds like its not engaging the whole way.and when I put to 4wd low theres nothing,no light for 4wd low on the dash.i pulled the motor,it changes to 2wd and 4wd high but wont change in 4wd low.maybe new motor is bad?
fr7
Lincoln NE
One way to test the motor is to plug the wiring harness, without the motor bolted on, turn the ignition to ON position or start the truck, have someone turn the 4wd knob to each position while you hold it and watch if it moves back and forth. I did it by sticking 2 pieces of wire to the positive and negative prongs it the motor and touching them to the battery, but I can't remember which wires I used exactly, so if you're not sure which wires then the first way it's safer.
40410
Poulsbo, WA
This is a common problem usually caused because of lack of use. You should always try to put your truck into 4WD at least a few times a year to avoid these issues. Just find a grassy field in the summer and do some circles in 4WD to keep the contacts fresh if you only use the 4WD in the winter. The more you use the 4WD the better the contacts.
