4x4 question
Newb
thanks for your help guys
Sunk
125
Everett, WA
3.5 Eco
Sounds like something within the front hubs. The automatic hubs on these Rangers are notorious for failing. Sounds like your transfer case is OK if it shifted into low-range. Check the Tech Library for the write up on how to install manual hubs.
Wicked_Sludge
43
Westport, WA
3-point-GO
or if you already have manual hubs, did you lock them in?
Newb
t
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
i have manual hubs and a push button. look at the center of the front wheel,if it's flat you have the dreaded auto hubs. if there is a knob you can turn you have manual hubs.
Newb
t
baddis
6
Avon,il
2014
did you hear a clicking noise from up front? here is the link on how to swap to manual hubs
Newb
t
PARKINGLOT
St. Thomas, ON
Jeep
5.2
because the low range would have engaged. I vote manual t-case and manual hub swap....
baddis
6
Avon,il
2014
any reliable parts store as for cost i am not sure i got mine from a previous vehicle that was getting scraped. you might go to a self service yard and find the parts to do the swap but remember that you need the spindle nuts from whatever vehicle you get your hubs from. also make sure you get hubs for a d35 not a d28 .
Newb
t
baddis
6
Avon,il
2014
correct. the auto hubs are shot or just in case make sure there is a front driveshaft installed. i used to work in a shop and a guy brought in a fs bronco wanting a new transfer case cause his 4wd wouldn't work and cralled under to see what tc he had and there was no front drive shaft
Newb
t
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
The transfer case shift motor is working. Otherwise you would not have gotten into the "lower" gearing you described. The low range is a second set of gears in the transfer case. The transfer case can still be in low range and if the hubs or anything in the front driveline is broken you will not have 4WD.
It is possible that your auto hubs are broken, as it is a very common problem. However, I would not jump the gun and replace them without checking everything else out first. When taken care of the auto hubs usually work well.
I would put the truck in 2WD and spin the front driveshaft with your hand. You can reach it from between the driverside front tire and fender. If it turns freely listen for clicking. If it turns a little and then stops it would appear the hubs still work....some... and they need taken apart and cleaned.
While you can easily go out and buy a manual transfer case and hubs, until you verify the problem your just throwing money at it.
mitch4x4
New Glasgow, Nova Scotia
Yeah sounds like the auto hubs are at fault here. The previous owner of my truck had auto hubs but put Warn manuals in.
