4x4 prerunner build.
aaron88
Las Vegas
kind of a 4.0
Well I have had a few two wheel drive trucks that have been fairly capable. The idea with this one is to keep all of the speed of the 2wd trucks and have the ability to get through most 4x4 trails. I do a lot of hunting and fishing that requires me getting back into some places that require 4x4 but first some pictures of my old trucks.
Now onto the new stuff started life as a bone stock 1993 4x4 4.0 autotragic unfortunately I have no pictures of it all stock. So here are some after wheels tires and fiberglass. Along with one next to my daily driver 4x4 5.4 2000 f150.
Then it was onto building a bed cage. Completely ditched the bed I'm running a 44 gal rci fuel cell, 2.5 Foa smooth bodies, deaver g50 pack kartek drop hangers with stock boxed shackles bumped and strapped at 17.
Decided to completely ditch the inner fenders up front because on my last two trucks they just ended up cracking a ripping apart over time not to mention trying to clear them at full bump.
Picked up some 6 over d35 ttb beams and weld it yourself radius arm brackets from Brandon at Btf motor sports wanted to build my own radius arms because I like a fairly decent amount of caster built into the front end. At that point I started building the engine cage at the moment it's just a single Foa 2.5 12in coilover with a 2.0 2in hydro bump but soon I'll be adding 3.5 bypasses out back and and a 2.5 14in bypasses up front. Also forgot to mention that I had the truck re geared 4.88s front and rear with a lsd out back just a temporary solution to the rear ended which will eventually be getting a 9inch once I can afford to put together a 3rd member.
I'll be adding some more pictures and stuff as soon as I get off work just doing this on my lunch break.
aaron88
Las Vegas
kind of a 4.0
Pictures of said 9in that will eventually be out back I just need to find a way to get a 4.88 gear ratio instead of the normal 9in 4.86 I know everyone says it will be okay but at times I do plan on running 45-50 in 4x4 so I'd like to have the same ratio front and rear that 2% will make a huge difference. And a few random welding pictures I'm not the best but I try.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
.02/4.88= .004% You'll be just fine with that difference in ratios. You could have more than that with tire diameter difference in wear.
Sent from my XT1032 using Tapatalk
bri113
Well I'm following this build!! This is basically what i want to do to my '98... as far as end result. Is it harder or easier to pre run the non A arm trucks? I went A arm b/c in the long run i know it will be the sturdier of the two. thats not to say the ttb front end wont get it done!
aaron88
Las Vegas
kind of a 4.0
I beam front ends are every bit as strong as the a arms and it's easier to get good travel numbers with ttbs that being said they don't cycle as clean as arm trucks do. Imo it's way easier to build beam trucks but that's just because I have built a few already and understand how to make beams work. If a you asked a guy that builds a arm trucks a lot he would say exactly the opposite.
aaron88
Las Vegas
kind of a 4.0
Started the final assembly of the front end before work today. I'll mount the bumps and limit straps after I check tire clearance up front.
aaron88
Las Vegas
kind of a 4.0
This happened truck is almost a roller
aaron88
Las Vegas
kind of a 4.0
Should be driving it around Thursday or Friday this week just needs a few little things intake parts will be here tomorrow. But all that's really left is double checking that all the bolts are tight hit them with a paint marker then it's off too the alignment shop. Oh and set the ride hight but that won't take too long the Idea is to get it registered middle of next week take out out for some testing before my trip.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
aaron88
Las Vegas
kind of a 4.0
No pictures yet but the ranger is on the ground rolling under her own weight need to track down a fuel issue though for some reason the pump isn't kicking on after the new front end I'm sure it's something small should be running and driving tonight
aaron88
Las Vegas
kind of a 4.0
Well I drove the truck around the block tonight I'll post pictures when I get a chance to take some during the day. Discovered that the 4x4 isn't working I hate this electric transfer case shit... Can't wait to swap it out for a manual one.
aaron88
Las Vegas
kind of a 4.0
aaron88
Las Vegas
kind of a 4.0
Late night started a bumper last night need to build the bottom hoop tie it up too the front tube cut and mount a skid plate then onto the upper portion of the bumper but it's nice to have lights again.
aaron88
Las Vegas
kind of a 4.0
