- Jan 24, 2023
- 10
- Sarasota, FL
- Ford Ranger 3.9
Morning! First post here - but I have been lurking around and used quite a bit of the info to tear the engine apart and replace the heads, head gaskets and oil pan gasket, and everything on the way in and out on the 2000 3.0. (Speaking of that… that oil pan sucks). Bought the truck knowing it needed engine work so I could wrench it out and give it to my nephew for his first car.
So here’s the question: now that the truck runs well the transmission seems to “slip” from a stop. Like I hit the gas and it revs and moves a bit, I take foot off the gas and it kinda chunks into gear and off she goes.
Reading around says the valve gasket in the tranny is the most likely culprit. So, here I am planning to drop the pan, pull the valve body and check those gaskets. I have never touched a transmission before. So despite pulling an engine apart, it spooks me a bit. But it seems pretty straight forward unless I’m missing something?
Second; I see these “new” valve bodies with a shift correcting/improvement kit already installed. If I’m pulling it out, is it worth it to swap out?
lastly: I can shift the trans as long as the key is on between all gears without using the brake. Isn’t the brake required to shift? If so, where do I check/fix to repair that issue?
Thanks! More posts to come.
