4.0 OHV Crankshaft Pulley / Balancer Removal
1BadRS
pinehurst, nc
I took off the center bolt and looks like you need to use a puller to get it off. I've seen a few different kinds of pullers and wanted to see what you guys recommend using.
Junk Collector
Truck of Month
4,800
Rapid City SD
Steering wheel puller and you can remove two of the long bolts that hold your AC compressor on with the puller to attach it to the pulley. It has a couple threaded holes in it. I usually thread the center bolt back in a bit and use the puller to push against that.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Steering wheel puller and you can remove two of the long bolts that hold your AC compressor on with the puller to attach it to the pulley. It has a couple threaded holes in it. You must thread the center bolt back in a bit and use the puller to push against that or else the puller will be pushing against the pulley.
Added a little info.
