33x12.50x15
eagleschoolroad
17
Parkers Lake, Ky
Good morning. I have a 98 Jeep Cherokee that recently died on me after purchasing new tires. How much lift would I need on a BII to use these tires (if even possible)? The wheel bolt pattern matches 5x4.5 (114.3 mm).
rusty ol ranger
2.9 Mafia-Don
7,726
Michigan
177 CID
Same bolt pattern.
33's IIRC would need 3 or 4 to clear good
eagleschoolroad
17
Parkers Lake, Ky
Can you all recommend a good lift kit that's sufficient and not too crazy expensive. Appreciate it
dvdswan
2,909
Seattle, WA
Ranger XLT 2WD
eagleschoolroad
17
Parkers Lake, Ky
Thank you sir, I'll do some digging in that forum.
rusty ol ranger
2.9 Mafia-Don
7,726
Michigan
177 CID
With these older rigs youre pry going to be limited more on actual availabilty then anything.
Just dont buy stuff off amazon or ebay witf unheard of names
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I've got a first gen BII that has a set of 33 12.5 15s on it. I didn't want to cut my fenders so I lifted it. Tech section has a good chart for tire size vs lift. I put a skyjacker 6" lift with 2" body lift. A bit too high but it all on there now. I'm thinking of going with 10.5s and taking the body lift off. Then I'll need new rims too. These are 10" wide.
I tried them on my 89 which has just 3" body lift. I had to trim some of the front fender and have a custom front bumper. Factory bumper would be rubbing. This set up is OK on the road but I think it would rub if I flexed much.
My skyjacker lift is by the piece not a kit. Using factory radious arms. Rear is all spring, no blocks.
gaz
679
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@eagleschoolroad ,
87 BII with 4" suspension lift, 33" rubber would rub in full turn, pretty close but clear of rear fenders.
87 BroncoII with a 4" suspension lift plus Bushwacker cutouts, problem solved.
eagleschoolroad
17
Parkers Lake, Ky
Thanks for all the info. Nice looking rigs!
eagleschoolroad
17
Parkers Lake, Ky
Sounds like too much so I'll do some research in you all's tech section. It stinks cause I paid a lot of money for those tires and put about 20 miles on the Jeep before it died. Guess I'll sell and go some smaller.
