- Feb 11, 2021
- Reaction score
- 2,909
- Location
- Seattle, WA
- Make / Model
- Ranger XLT 2WD
- Engine Type
- 3.0 V6
- Automatic
- 2WD / 4WD
- 2WD
- My credo
- Keep your mind like an umbrella, it only works if its open... Continually learning.
Just washed the truck, did a quick cleaning of the engine compartment, it was not hosed down. Started the truck to let it warm up, finished vacuuming the interior and the belts were squeaky/chirpy, so I shut the truck off. (it was running for about 5 minutes, temp was still cool). Finished up cleaning the interior then went to start and no fire. I can hear the fuel pump prime then stop when it get to pressure, it cranks just fine just doesn't fire up.
I'm sure I got a connector wet but which ones should I check? I did check coil and plug wires at the distributor and they were dry. I'm guessing its one of the sensors. Any thoughts?
Thank you for looking.
Edit: Just after posting went back to the truck. It fired up reluctantly. Sun must have dried the connector. Mods you may delete this post if you wish. Thank you.
