3.0 intake manifold bolt kit
fithers
NYC
v6 3.0
This worked out pretty well. I gave myself a little space above the nuts just in case. Running like a dream so far with no CEL or codes, passed NY State inspection, and 70 miles today. Hopefully my cylinder 5 misfire and lean codes are finally sorted out. Now to wait for the next issue to arise ha.
blg1994
Rockwell nc
Ford ranger
ended up getting some M8 1.25 20cm allthreads from McMaster-Carr, will double nut and cut down to size for the shorter bolts. Ford has left me no other option ha
Did that work? Running into the same issue. Thinking of going to pull-a-part and taking some out of one those. Just a long drive for me and the issue of them maybe not even having anything. Please let me know I'm desperate at this point haha
blg1994
Rockwell nc
Ford ranger
www.belmetric.com. They should have what you need. A bit expensive as you have to pay for the shipping and the fact that the bolts are weird sizes, but they have a huge selection of metric fasteners. Do you need the bolt call outs? I think I they are listed in the factory service manual I have.
What are the bolt call outs if you dont mind? Having same issue
mc17eln
33
Diamond Bar, California
Ford Ranger XLT
@blg1994 Isn't that specific enough? at most 20 cm long, cut off the top if too long.
I think the problem here is folks over-torque the heck out of them. Dude, they are for air and no turbo. Go easy. Here is from the workshop manual for metal in-take manifold (plastic only need 10nm on all bolts):
6. Install the three bolts and the three stud bolts.​
  • Tighten the bolts in the sequence shown in two steps.
    • Tighten to 20 Nm (14 lb-ft).
    • Tighten to 25 Nm (18 lb-ft).
