3.0 in a mustang
C.Fuller305
5
South Carolina
I have a 1993 Ford Mustang LX that had a 2.3 4cyl blow up. Now I have a spare 3.0 out of a 1993 ford ranger sitting in my garage both vehicles have the same transmission but I can’t seem to find any information on motor mounts or what else might have to be done for this to work. if anyone has anyone has any suggestions or needs further information just let me know
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
Motormounts, bellhousing, wireing, all will be different.
It would be as much work (probably more actually) then swapping in a 5.0.
fastpakr
2,833
Roanoke, VA
2.3 turbo seems like an obvious option.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Sell or trade the 3.0 for something more compatible with the mustang.
Or don't listen to us nay sayers, and build that car. Probably need custom motor mounts and a few other pieces, a good junk yard will be your best source for parts, and document everything for the next person who is thinking of a similar swap
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
If you do it, let us know how it turns out.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
If you can't trade it for a direct replacement....
And you have it all. .. 👍 run it
don4331
1,346
Calgary, AB
5.3
@C.Fuller305 Looking for some clarification - you have a spare auto for the 3.0? Or at least the bellhousing for the Vulcan? Because the bellhousing pattern is different between 2.3 and 3.0 so you can't directly swap transmissions (but you could remove the 2.3 bellhousing and install a 3.0 one and go from there).
Not a swap I would do, but interesting...
tinman_72
136
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
OP didn't state whether trans is auto or manual. I don't know about the automatic but the manual trans in these do not have removable bellhousing.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Seems it's moot.....has it all
Dew eeet.
racsan
4,442
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
put a 383 in it, the opposite of putting a coyote in a roadrunner.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
rusty ol ranger
2.9 Mafia-Don
7,495
Michigan
177 CID
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
I have a friend that just put a 383 in his S10. Bought a built crate motor, transmission, and 9” rear. 2nd pass at ATCO and he’s only got a 5cly.
19Walt93
4,466
Canaan,NH
351
3"
235/55R16
Instead of spending a fortune to install a 3.0 and not make much more power, if you don't want a 5.0, rebuild the 2.3 and stick some deeper rear end gears in it. I like 3.0's just fine but I don't like lots of work and expense for minimal power gains. I guess it would be unique. There was a Pinto at Carlisle with a flathead in it that was cool and unique but it added a ton to the front end and may have cost him some hp. I've never been cool so being faster is more important to me.
