- Aug 7, 2007
- 38
- Farmington, Pa
- Ford F250 4WD
- Engine Size
- 3.0
My 2000 3.0 4wd MO5D came with 245/75-16 tires and 4.10 gears.
It rode jouncy and gave average performance.
Years ago, I put a set of Explorer take-offs (Craigslist) Dueler AT Revos, 235/75-15.
They woke that truck up nicely, with better take-offs and 5th gear was more responsive. I had to adjust my expectations of the 4WABS system when I did that, but it still works well.
Kept that size for years, and was happy to install new same size Michelins LTX MS a few years back.
Yesterday, I traded my son (his tires wouldn't pass inspection and mine just did pass) for the 235/60-16 set that I had put on the 2000 2wd 2.5 that I gave him last year. It was a peppy truck and handled far better in turns with the lower profile tires.
Great googly-moogly, what a difference that made. I had previously gotten in the habit of pulling out in second gear when putting around in no hurry. Now, I pull out in second and stomp it, and 5th gear is a pleasure. I drove it from Fredericksburg, VA back to NC last night and loved the whole performance difference.
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
245/75-16 7.2in 15.2in 30.5in 95.7in 662 0.0%
235/65-16 6.0in 14.0in 28.0in 88.1in 720 -8.0% <corrected on edit
I've commented on my tire switches in the past, but this is the final result that I am so very happy with.
To those who say that my highway mileage will suffer, bullhockey. I barely hold the throttle open and had to relearn/adjust my foot pressure to keep from that accel/decel spot.
To those who say my high speed rpms will be too high, bullhockey again. I ran 70-75 mph down I-64 and it stayed in the 2700-2900 rpm range and my Vulcan was very happy to be there. When I ventured north of 3000 rpm in 5th gear, I was in peril of being cufffed and stuffed and THAT is where the Vulcan really makes it power, above 3k. From 75mph to the speed limiter happens faster than I thought possible with this truck.
Yes, my 4wd looks just a little odd with little 27" tires, but no worse than a 2wd with their little 15"s (stock on the 2.5 truck was 215/75-15).
Lastly, you can not believe the way it handles so much better in turns. There's a lot to be said for short, stiff sidewalls.
FWIW, I don't off-road this truck anymore (quit hunting) and all I use the 4wd for is in snow when I go up north.
His tires wore uneven due to bad LBJs, which we replaced yesterday.
