2wd to 4wd on a cummins
twoll86
9
caseyville,il
ok my grandpa has a 96(i think) dodge 2500 and i'm think about getting it from him but i want a 4wd diesel what would it take to swap it over (alot of fab work?)
stegomon
20
auburn/minot maine
fords and only
will have to do a SAS. also new steering linkage and new trans and t-case. also drive shafts
Redjosh
finlayson mn
1996 and 2008
dodge
tcase
trans or adapters to mate with a divorced tcase
cross member for tcase
drive shafts front and rear
mounts for control arms
front axle(most axle assblies come with steering)
steering box
plus wiring
fluids
that's all I got for now
It wont be cheap but if I was going to do it I would get a whole 4wd rolling chassis and swap from there just make sure its a 2500 rolling chassis
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
custom front suspension. the 2wd is different chassis wise then the 4x4.
if it is an auto you can just put the 4x4 od section on along with the t case, depending on what manual setup it has that can be simplified as well.
the rear d shaft if using oem parts can be used from an oem application obviously.....but the front may have to be custom depending on how you choose to mount it.
i dont know if i would prefer leafs or coils for such an install.
