howlinghuskie
- Mar 2, 2011
- 0
- Abrams, WI
- Ford
- Engine Size
- 2.9
How much lift will I need in order to run a 29x10.50-15LT TSL Thornbirds? The truck currently has a car 215/75R15 and the door tag said it came with 205/75R15 the speedometer is right on so the gear was probably changed. I know Ill have to change the gear again. Also will the axles still be fine with 3.73 with a 2.9 and a 5 speed? Would it be enough to just put a coil spacer in the front or will it need more lift?
