2008 ford ranger mpg
southernboy2147
Gray,GA
What kind of gas mileage can be expected with a 2008 ranger sport 4x4 with the 4.0 and 5spd thanks in advance
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,649
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It depends where you drive. On US and State Routes at 55mph or less? Somewhere around 23 mpg. On Interstates where the speed is usually 65-70 mph, figure more like 19-20 mpg. Straight City, no idea. I average about 18.5 mpg over all with my 2011, which is similarly equipped as your 2008.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
My 06 Sport has never seen 23 mpg's... 20.8 was the best it's ever delivered. My average was a little less then sgtsandman at 18.2... most of my miles are blowing down the tollways at about 70 mph. I did upgrade tires in the last couple thousand miles... I need to check it again. I was hoping for an increase with the 32... well 31.9 inch tires. It dropped just about 300 rpm at 70 mph.
sgtsandman... I know you just went to 265's yourself... You checked your mileage after they went on?
sgtsandman
Ham Radio Operator
12,649
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Yep, mpg is about the same once you do the conversion for the difference in the tires. Miles X (new tire diameter divided by OEM tire diameter) divided by gallons refueled = mpg. Is working out about the same as before the new tires. Obviously, its worse if you don't do the conversion by about a mpg or two. I hashed that formula out with my 1999 Honda CR-V after I had up sized the tires on it and bounced it off a few brainiacs in order to make sure I wasn't throwing crap into the computation before running with it.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
647
Central Indiana
Most owners with the 4.0 SOHC average about 17mpg:
The manual will give you more of a chance to beat that, but I wouldn't go in expecting anything better than 18-19mpg.
