2007 Ranger XLT Limited Edition
Tommy T Jackfish
Kenora Ontario
Ranger XLT
I’m having some kind of electrical issue, when I try to start my truck, my instrument cluster only shows the red lock/truck icon. Fan and lights work fine, and on occasion is will all of a sudden start when turning the key. Battery and alternator are fine !
need help !!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Are you getting an audible "click" when you turn the key to start?
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Have you tried wiggling the gear shifter... or try starting it in neutral?
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Being it's intermittent... I would ensure you have good connections at the ignition switch.
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I moved this to the electrical forum... FYI
I also have a factory Wiring Diagrams manual for my 06. If you need them I can post you some info.
Tommy T Jackfish
Kenora Ontario
Ranger XLT
Thanks for your help, I’ve resigned to having it towed to a garage. Hopefully they will have it up and running soon.
Tommy T Jackfish
Kenora Ontario
Ranger XLT
As a follow up on the electrical issue of my 2007 ranger XLT. Turns out it’s the control body module, and the manufacturer no longer makes them. Now the search to find one.
